T5 Like new again
hole
Crazy Sr. Respected Jeeper
- Media
- 28
- St George Utah
- 83 CJ 8, 258 I6, T19, 4-1 Dana 300,4.0 Head, Mopar MPI, 10k winch, OME YJ springs w/3" lift,CS 144 Alt upgrade,Locked 20 & 30, Border Collie co-pilots are stock.
Well, almost. I was changing out the worn clutch linkage yesterday, and thought it was time to change the fluid in the T-5 Transmission . I knew that it had gear oil in it, and also knew that ATF was what it came with from the factory. I did a few Google searches to see what people were running and came across a thread from another Jeep forum with alot of different advice. The one that stuck out was a post by a guy who said that he'd built T-4 's&5's for over 20 years. He admitted that they indeed had their issues, but recommended Penzoil Syncromesh for the fluid. He touched on all the problems that I was having by using gear oil,hard shifts,grinding,wont go into gear etc. Well, I put it in and was blown away by the immediate difference. Ive never been able to put it in reverse from idling in neutral without grinding, so that was my first test. Passed with flying colors!No more gear noise while idling, smooth as butter shifts. I'm looking forward to a nice long freeway road test to see how everything is , will report back later tonight as I'm headed out the door to test run
