Those running Detroits in the rear...
j6824
- Central Virginia
- '78 CJ5, 258, D30, AMC 20, 3.54, T150, 33s, Sniper EFI, 4"BDS, 1" M.O.R.E. body, Team Rush, MDS 6A, BDO tie rod flip, Adams shafts, Speedhut gauges, 8274
Got an opportunity for a good deal on a swap in 14 bolt rear in the right ratio that already has one installed, so I was hoping to pick the brains of those who are running them...
Other than learning the difference in how it will handle and the chirp of turns/tight curves...and cons to it at all?
I know guys are running them up front...wasn't so sure about out back.
If I'd be better off... say, moving it up front and going with a selectable in the rear... I'd like to know ahead of time so I can have it done prior to install.
Just as soon not do this more than once...unnecessarily, that is
Thanks in advance
Thanks in advance
