Throwout bearing contact
The return spring pulls the T/O bearing away from the p'plate 'fingers'.
The pedal freeplay is the 'gap' from T/O to the fingers.
The freeplay in the pedal becomes less, as the friction plate wears and the gap from the f'wheel to p'plate becomes less.
No as the disc wears the fingers of the pressure plate move inward which means the other end moves outwards towards the throw out bearing. I hope you understand how I'm explaining this.
It makes a little sense I'm not totally grasping it though [emoji848]
Since the fingers act as a lever, their fulcrum is in their middle. One end touches the pressure plate, the other the throw out bearing. As the throwout bearing pushes their end forward, the other end pulled the pressure plate rearward, away from the flywheel, releasing the friction plate. Think of a see saw. One end goes up while the other goes down.
Now, when Lumpy said the free play decreased as the friction plate thinned due to wear, that took me a second to wrap my head around it - but applying the see saw principle clears it right up......
