Tie Rod Bar Clearance over Leaf Springs???
project74
I just mocked up my new tie rod bar assy. and the clearance is real close.
I am running a stock Dana 30 axle, 2-1\2" procomp leafs and installing the tierod bar from under the knuckles like stock...I have apx. 1\2" of space between the tierod bar and the leaf spring. This should be enough because I dont think the movement of the leafs will be enough to hit it...should I install the tierod assy. from above the knuckles...? Would this cause any other problems with the linkage?
Let me know if anyone has any thughts.
thanks, Ed
thanks, Ed
