Tie rod/drag link
Jodowd84
- massachusetts
- 1985 cj7 4 inch lift stock 4.2 liter weber carb. Dana 300 t5 trans
I recently purchased a heavy duty tie rod and drag link for my CJ7 the new one as well as stock one mounted to knuckle from the bottom with castle nut on top. I've seen people with the tie rod and drag link on the top instead but the hole in knuckle only allows it to fit from bottom has anyone done the over the knuckle? If so what did you do just use reamer to make hole bigger?
