tie rod end
Funnyjeeper
- Germany south west
- CJ7 86, 4.0L, T5, Dana300, front Dana30, rear Dana44, disc brakes front and rear, twin sticks, 33x10.5 r15, RE 2.5"lift and yj shakles 2" bodylift
Thanks a lot Torxhead,
so you are basicly saying i should better get weldet in bushings.
OK but I also found out that these are not made for the CJ original Taber of the tie rod ends.
They are most likely TJ tie rodends.
The diameter seems to be the same, but the ancle is different. so when you redid your steering linkage, did you use TJ tie rod ends?
Frank
