Tie Rod Flip with spring-over lift?
jonboy1919
- Media
- 49
- Maltby, WA
- 1979 CJ7 Renegade, 304cid, MC 2150 Carb, TH400 tranny, Dana 300 twin stick, Dana 44 front w/lock right, Dana 44 rear w/truetrack locker, 33x12.5 Goodrich's, Warn 8k, onboard air, Motorcraft TFI ignition upgrade, WipeBoy wiper upgrade, Painless wiring harness, backup lamps, Driving lamps, YJ brake booster and MC upgrade swap, Rear tow hitch
I have searched through these forums looking to decrease my steering radius. It appears my dropped pitman arm is the culprit. It seems that the "Tie Rod Flip" conversion is the answer most all are saying.
After eyeballing my front-end steer components, it seems that because my jeep has a 4-inch spring-over lift (instead of a shackle lift) that my springs would conflict with the tie rod if it were to be flipped.
Is this true? If so, is there any other method to decrease my steering radius?
I've seen a photo of Old Dog's tie rod flip, very nice indeed, but he has a lift via shackles and his springs are under the axle.
Here are a few photos of my rig. Any suggestions?
