Tie Rod Problem
ColoradoCJ
- Colorado Springs, Co
- 1985 CJ7 Laredo, 4" Susp Lift, 33" tires, ARB Air Lockers front and rear, 4.56 Gears, Rock Sliders, 4.0L Fuel Injected Engine.
Today I tried to get my tie rod ends changed. I got the tie rod ends to drop out , and I got the drag link to fall out of the pitman arm, but I can't get the other end of the drag link to drop loose. I'm not up on the terminology, so here's a picture of what I'm talking about. This is just a picture I found on the internet, not my Jeep. If you were to raise the tie rod end up until the places that the arrows are pointing two were together, that is what my Jeep looks like now.. I'm trying to make it look like this picture.
I've hammered, sprayed lubricant, etc.. everything I can think of. Is this something I can heat up and not worry about messing up? I've never torched anything, but I guess there's a first time for everything. What is that called? Steering arm?
