Tie rods and tie rod flip
I damaged my tie rod and draglink beyond repair on my 6, and I'm making up new ones using heavy wall tube and threaded inserts. To avoid obstruction with the springs I'm looking at doing a tie rod flip using Goferit inserts. My question is I have a RHD Jeep that uses the special "Y" branch style link up to the tie rod from the draglink, I was considering drilling an extra hole in the LHS knuckle just like that of the typical RHS knuckle (double hole) and just converting to normal LH/RH threaded tie rod ends like you guys have on your LHD Jeeps (mine would just be the opposite side). Can anyone see an issue with this? Anyone ever heard of doing this.
