Tilt colum binding
venom
Hey guys, I've come across an issue with my steering column and I'm not sure what's going on. It went from fine to bad in a matter of minutes.
I got my CJ running again, after sitting for a few months, and after driving it a couple times I brought it home and couldn't get the key to turn off. It seemed like the lock cylinder froze. I ended up stalling it to kill it and disconnected the batter. The key was still in the "run" position.
I bought a new lock cylinder and pulled the steering wheel. That's when I noticed that it was harder to turn and that the tilt function seemed to be bound up a little. Once I got the wheel off and the old lock cylinder out I could feel that the tilt was even stiffer. I haven't completely put it back together yet because I'm not sure if there's anything I should look at before I do. I just don't know what, beyond the turn signal wiring, might be causing it, or if I'm overreacting.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
