Tilt steering column shaft moving in and out
Bellworx
- Los Angels CA
- 1977 CJ5 Levis Renegade 4.2L ,T18 1B, Dana 20
1982 CJ7 Laredo 4.0HO, T5, dana 300
1977 CJ7 Golden Eagle 327, TH400, quadratrac - deceased
So I purchased a used cj tilt column. The listing showed the spline portion sticking out of the bottom like it should. When it arrived the spline end was barely sticking out. Clearly it had recessed back up into ths column. My guess would be the slip shaft has been compressed by a wreck or someone has dropped it. My question is this, is it ok to use this if I can pull it back out? I read there are pins that shear off to allow the shaft to collapse in a wreck situation. I just dont know if it is safe to use or if it will cause other problems not being held together as it should. Thanks
