Tilt steering
Rippy
- southern Illinois
- 1979 cj-5,fiberglass tub,258 engine,3-speed,basically stock
I found a local shop that worked one over for me,did a real nice job,all switches and replaced the bearing as well,will be putting on tomm,thanks for the help Rippy
A 92, 93 chevy blazer column will bolt right up. In fact the adapter for the steering wheel is the same as the cj.
This info saves me a new post. I bought a second-hand Grant steering wheel with GM adapter, and saw an eBay auction that lists the same adapter for CJ5 as for GM. Was wondering if the GM would bolt right up to my column. Looks like it will. (Haven't pulled the old wheel yet because I'm a driveway mechanic and the weather has been cold and wet.)
They aren't hard to work on I would try spraying some WD40 in it first and working it back and forth.Similar question. Just bought 84 CJ7 has tilt wheel (original I assume?) but the wheel lock lever is very stiff. How difficult are these to work on?
