Timing cover problem
jakeh937
- Petaluma, CA
- '79 Cj5, 258 with Howell Fuel injection kit, T18 with dana 20 Tcase, dana 30 front with Detroit locker, AMC 20 rear with LSD and one piece shafts, Warn 8k winch, 1" body lift, 2" suspension lift, 33 tires
I bought and installed a new timing cover from summit during my engine re-build. All machine work has been done through a well known engine shop in town. I installed my harmonic balancer, only to find its rolling the timing cover lip seal on one side. It's as if the cover or seal is off to one side farther then the other when comparing it to the crank. Any ideas? Any suggestions? I loosened the bolts and it wouldn't budge. I'm at a loss and frustrated.
