Timing marks
Vikingone
So I pulled the timing cover off to check the chain. Set the engine to 0 degrees TDC. Distributed rotor lined up to cylinder #1. Once I got the timing cover off marks on the gears weren’t lined up. Lined up the marks on the timing gears and found the distributor rotor lining up to cylinder 3
