Tire and wheels.
Tire and wheels.
Manic Mechanic
Full Time Jeeper
Thurmont MD
85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
This may not be the best section for this but whatever.
So I picked up a decent set (5) aftermarket CJ7 wagon wheels 15x7 my question is would putting my 33x12.5 BFG km2 on them be ok for wheeling or should I try to find some 15x8 waggys??
Sent from my E6810 using Tapatalk
You're fine.
Run the TP around 24-26 psi on the street.
My current setup is factory 15x8 wheels and 31x10.5 tire's. I run at 9psi off-road and 28psi on road
With my 33's, I run 12-14psi in the rocks, and 10-11psi in the sand.
I do mostly rocks and streams in the mountains of Virginia never had a problem running 9psi on stock steel wheels. But I have always had an 8" wheel. I didn't think dropping to a 7 was going to make much of a difference
You'll be fine with the 7's
