TJ Dual Diaphram Brake Booster Swap.
ThisGuyUKnow
Full Time Jeeper
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Yep you read that right, TJ. Come on you guy should expect this from me by now.
A fellow jeeper and I (I will not name names just incase he doesnt want to be named in the addition of wrangler parts to a CJ) took apart a rusted out TJ the other week in order to sell of the good parts left over. During the process I got to take a good look at the inner workings and designs of many tj internals that I had not really seen up close for a general lack of interest in TJs since I got into jeeps years ago.
A while back I put a Hydraboost in my CJ7 . And I want to say it is a very cool and very good upgrade;however, I run 30s currently and plan to go no larger than 31s in the future of my 7. That HB can lock up the brakes in an emergency stop with my set up on a dry day at any speed. This is great when its DRY. If the roads are any bit slick any sudden stop locks up my brakes and sends me sliding down the road if I am not very conscious about how much pressure I put on it. I think that the HB is just too much for 30s and would be better paired with 33+ tires.
Well we all know that the YJ booster is supposedly a better braking booster than the CJ power booster. AND it is common internet lore that the dual diaphragm brake booster from the 1995 YJ (only certain 95s) is dual diaphragm and more powerful than the single diaphram booster of the previous years.
It appears that the knowledge of the fact that the dual diaphragm booster is a desired part and the fact that they truly are pretty rare has driven prices up to above AMC 150 bucks for one if you can find it.
Back to the point. When I removed the booster from this TJ (which is a dual diaphragm for all years)i took a long look at it and thought too myself, I wonder what the differences are between this and the YJ dual Diaphragm set up.
The first thing I did was measure the bolt pattern and check it against the YJ brake booster bracket. To elaborate, the TJ BB mounts directly through the fire wall but the YJ booster (all years though the DD ones are slightly different brackets) have a brakect that mounts directly to the BB and to the firewall/pedal assembly. What I found that the TJ booster is close enough in bolt patter that it can be mounted in place of the the YJ booster if you take a larger drill bit and widen the holes.
SO it mounts to the same bracket.
Next I did some parts crossreferencing and I found that, surprisingly, The MC for the brakes is actually the same PN between the 95 and TJ brake boosters
HMMM interesting.....
Then I took a look at the rods (now keep in mind no super exact measurements were taken) side by side the push rods that connect the pedal to the booster look to be almost identical with the exception being that the TJ rod is shorter than YJ booster because it is mounted directly to the fire wall. (for anyone wondering, I am 99.9 percent sure the YJ BB has the bracket to space it off the firewall in order to clear the Hydraulic Clutch MC, this is why the push rods have to be different lengths) by the same I also mean that they have the same contour at the end of the pedal that allows the rod to stay relatively center and swoops down to mount to the brake pedal stud.
OK so with a little fabbing we can extend the length of the input push rod. Looked into rod removal and its not worth the time.
Finally, not having direct access to good information or a 95 yj booster I googled as many images of a 95 booster and a 97 plus booster and you know what, I have been wrong before but I would say judging by the body of the boosters they are the same part.
So the conclusion I was left with was that, if using a YJ booster bracket (which has the correct bolt pattern for the CJ firewall/pedal assembly) I should be able extend the pushrod and use what ever adapter (cant find them in any searches) people are using to adapt the 95 YJ dual diaphragm BB to their CJ7 brake lines. IN THEORY mind you, I should be able to get the desired Dual diaphragm BB for free in this case, but had I not had access to a free TJ booster, they go for around 25 bucks on fleabay vs AMC 150 for an authentic 95 one. And if my theory holds true next week when I put it into practice, the only compromise Ill have to make is cutting the pushrod and extending it to the YJ length.
I will definitely include pics as I intend to tear into this monday when I return home.
Will it all work and brake right? I don't know, I will let yall know next week!
