Suspension To weld or not to weld
b3uhbp
- Arlington, TX
- 84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
To Weld or not to Weld
I replaced the suspension on my 84 CJ7 with an OME 2.5” lift. Love it, BUT, the rear spring hangers are bolted on like original. The original hangers were welded on by the PO. I’d like to get opinions as to whether I should weld them as well. This Jeep is for street and mild trail. I hear some popping when I go over uneven ground and I suspect it’s movement at the spring hanger. Thoughts?
