Toe Alignment
O.K. Jeep gods, bare with me, this will be a long winded post...
I changed my tie-rods a little while ago and finally got time to set the toe... I used the old school method of wrapping a small nylon rope around the back tires, through their center point, and placing the ends of the rope on pedestals at the front of the Jeep... Some of you probably know what I am talking about...
With the front tires pointed straight ahead, their toe was definitely out of alignment... It appeared that the pitman arm was not lining up where it should be... So, I broke the pitman arm to tie rod joint... Turned the steering wheel in order to see how many turns it takes to go from one extreme turn angle to the other and then placed the steering wheel in its center... Next, I broke one of the joints on the center link rod... This allowed me to move the tires independently, set their toe, adjust the joints where they need to be and put it all back together...
After I was finished, I turned the steering wheel all the way to the right... The back edge of the passengers side tire and the front edge of the drivers side tire were about 1/8" from rubbing on the leaf spring... When I turned the steering wheel all the way to the left, the back edge of the drivers side tire and the front edge of the passenger side tire were about 2" from the leaf spring... It looked like the entire front axle had shifted towards the passenger side... I do not think that happened because the leaf springs, shackles, mounts on the axle all line up... With all of that said, the Jeep drove fine except when I make sharp right turns, the tires rub the leaf springs...
Is my steering gear/pitman arm not centered? Can anyone tell me a measurement from the frame that the pitman arm should be when centered?
