toe problem?
dalefan88
Crazy Sr. Respected Jeeper
when i just crawl my steering wheel is straight. as soon as i get any kind of speed my steering wheel almost goes a 1/4 of a turn to the left. would a toe in or toe out problem cause this?
Dalefan this is how I set my toe in.
Jack up the Jeep and make a wide chalk mark all the way around both tires, (sidewalk chalk works good) now take a nail and rest it on something solid so you can scribe a good straight line around both the tires. Now measure from line to line (get someone to help) the front should be 1/8" less than in the back.
my exfriend turned my camber sleeves cause he didnt know what they did. now the top of my tires lean out.
That can't be helping any.
It's always nice to have friends help ya out.
before you adjust your steering check all steering components. Check the tie rod ends by pulling on them and looking for free play. Jack up the front end and lift on the front wheel. This will check for free play at the ball joints or wheel bearings.
