Transmission Advice
I recently purchased a '83 CJ7 with the (SR4 ) 4 spd Transmission . It is going to need a rebuild sometime in the near future. It is the one with reverse to the left and up by 1st. Supposedly you are suppose to have to push down on the shifter to go into reverse but not on mine. It will go into either 1st or reverse just as easily. That can be a bit of a problem if you are not paying attention. The Jeep will be used for light duty only and as a second driver with little off-road use. My question is would it better to just rebuild what I have or replace it with one of the more desirable Transmission ? Budget is an issue so if there is no significant reason to upgrade for my use then rebuilding the SR4 seems like the cheapest option. If I were to replace it which Transmission is the easiest swap with the fewest additional parts (mounts, adapters, etc) needed? Thanks for any feedback...
Chris
'83 CJ7 AMC 258 i6 / 4.2l 4 spd
Austin, TX
Chris
Austin, TX
