Transmission question
I agree there is no telling what Transmission you have being it has a sbc engine. But if you want to get some good factual information on transmissions and may help you identify what your setup is, I'd suggest exploring Novak's website. It might give you clues as to what you possibly have now and what you is the most desirable transmissions to use behind a sbc engine or any conversion for that matter. Tons of info on that site. It will break down what transmisdions have what, like gear ratios and mayne shift patterns as well.
From the sound of it, are you looking for a different Transmission ? Also, what do you refer to as a four speed? Are you counting reverse or not? I currently run the stock T-150 Transmission . It's reverse is also up and left. My NP435 is a ford truck Transmission I will be converting it over to and it's reverse is down and to the right. So are you lookimg to convert or just trying to identify what you have? Novak would be a good place to start looking.
I do not count reverse as a gear. I am trying to understand what I have so I can prepare to replace if need be. I would love to put a 5 speed in it if possible but not sure yet
Was not trying to be insulting. You would be surprised. I was looking at you working on a CJ5 , I think had two options in a cj. A T-150 which is a 3 speed, and a "jeep" T-18 which is a 4 speed. I am trying to figure out if they did an entire drive trane swap or did just a different swap using a conversion bellhousing. You would be amazed at corner cutting people do on swaps. So just trying to figure out what you have, reason for the question.
Posi is right. Post some pics if you need help figuring out what you have.
Sorry if it offended you, not my intention.
If the Transmission is original to the Jeep it would be the SR4 and the 7th digit in your vin would be A, C, or E.
If it’s not original and the 7th digit is an H it would have been a T-176 .
The T-176 was also found behind the AMC 232 i6 , and AMC 258 i6 / 4.2l as well.
Much easier to post pics and codes.
Not offended at all and will take pics this Sunday. Planning on doing some work on the jeep then.
Casting #s should be top cover.
Where would the casting numbers be? I tried looking for the casting numbers but could not find them.
