Troublesome Dent Removal
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
It's not surprising that somewhere along the way my 38 year old CJ5 got one of the most common dents found on any CJ Jeep. The common hood dent caused by the hood smacking down overly hard on the windshield, or would it a hood crease? No matter we all know the blemish I'm talking about. The question is how to remove my not horrible but annoying dent.
I have a slight edge dent and a crease with the corresponding low spot in the middle right where you can ALWAYS see it. I saw on an automotive program where they used heat to remove hail damage which is surprisingly similar to the jeep crease. They simply used a little heat about 12" outside of the dent. start slowly circling around the dent, it looked like they moved ever so slowly inward toward the dent using only the smallest amount of heat possible. Not enough heat to damage the paint. As they moved the torch suddenly POP the dent removed itself. They said that metal has a memory and if treated correctly would return to it's original shape without using a hammer.
My question is, have any of you done this? If not have you removed one of these dents, how did you do it, and was it successful.
Sure I can remove some of the dent and hide the rest with body filler, but the more natural the fix is the better. The paint on the side of the hood is good, I plan on painting the middle flat black, actually not the old fashioned impossible to clean flat black, I want to use that incredibly smooth flat paint you see on hotrods and motorcycles.
Any advice would be appreciated. Thanks
Michael
Michael
