tube steel for cages sorce?
raser13
festus,MO
1977 CJ-5 '83 amc 258 straight six, motorcraft 2100 carb ,inline fuel pump, 1000 cca battery ,T-175 tranny,
Hey guys, were do you guys get your tube steel that you use for cages, bumpers, and such? Is it the same place you get your steel plate? Or is ther a good place to get that? If anyone knows of a good spot in the St. Louis, Mo area that would be even better.
I get my ERW tube from Smilies racing in Mesquite Tx. Only because they are a couple miles from the house and can make the bends for me at a reasonable price. Check for a shop that does business with the local stock car builders and they will be able to help you out. The trick is to avoid shipping costs, they will be more than the cost of the tube.:cool:
Industrial Metal Supply carries CM, DOM, steel and Black Iron. There are several around St. Louis. Which doesn't appear to be very far from where you are listed. Warning IMS is a big boys toy store. You won't walk out of there without project ideas.
