U-bolt flip
U-bolt flip
Patrick
Old Time Jeeper
El Paso, TX
82 CJ5, LS 6.2, NV3550/D300, D44/30
68 CJ5, 350, Muncie/D18, D44/27 under construction
Greetings everyone. I would like to flip my U-bolts on the front Dana 30 wide track non lifted CJ. The headache is the side with the bigger U-bolt going over the pumpkin cast end. My shocks are not mounted on the spring mount plates, so half the battle is done. Does anyone know a practical solution...
Nothing. Just a little bit of undercarriage clearance. I like how they look, if done correctly.
If you've ever sat on top of a stump with the U bolts dug into it, You would know why. It is for a little more and cleaner clearance.
Very true, Caveman. I just don’t want to start a debate here. Just an answer to my post. Thank you.
