u joint angle
cjnewbie
so how much diffrence from the pinnion to the drive shaft is exceptable and from the Transfer Case to the driveshaft?
ok thanks guys i put a 4 inch lift and i think i have something going on becuse my rear pinion is pointed up just a little becuse the wedges that are on the rear springs this was a used lift so i wonder if the wedges are suposed to be there i have about 500 miles it since the lift and have had no problems but it still doesnt look right to me if that makes sence
