ujoint retaining straps?
raser13
- festus,MO
- 1977 CJ-5 '83 amc 258 straight six, motorcraft 2100 carb ,inline fuel pump, 1000 cca battery ,T-175 tranny,
hey guys this is kind of a weird question. my '80 CJ5 has little straps on two of the sides that hold them to the yokes. i need a source for good ones.
http://www.pirate4x4.com/tech/billavista/PR-1410_Yoke/images/DCP_9279.JPG
the PO rounded every bolt that held them on.
i found this out because i had to change the clutch. since i had to remove the bolts with vice grips and chisels i went to the parts store to get new straps. the only ones they had that matched mine were in the little help section. the looked cheap and were made in china. so i passed and went to all the other local stores to see what they had. they showed me the same thing. so i ended up buying the 8 that it required to replace them all.
big surprise i get everything done put the jeep into reverse and the @#$%$#$%%
things shatter! i mean into 3 pieces shatter. like they're mad of glass. i didn't gun it. i didn't let the clutch out fast. nothing to over stress it just get it out of the garage.
so where do you get yours? who has good grade ones? is all the part stores have here are the same junk! i'm not putting that crud back into my jeep! i need your help badly and quickly. i really need it back up and running
