Unable to Get Into Gear
JeffWalden
Recently it's been more difficult to shift into gear, namely 1st and 2nd. I had to almost put all of my body weight into it to get the shifter into place, though no grinding. The last few rides though, trying to get into reverse has had grinding.
Then it got worse. Today, I can't seem to get into any gear except reverse (with grinding). When I did get it into reverse, didn't matter that I had the clutch pedal completely to the floor - the truck lurched backwards.
This is my first time working on a car with a clutch, so please excuse the ignorance here. Am I correct in assuming the best place to start here is going to be the clutch or the clutch cable? In my logic, if the clutch wasn't being engaged it makes sense that it was tough to get into gear. Even with the clutch pedal to the floor, it seems that the clutch wasn't disengaged which is why I lurched backwards.
Looking for the best place to start here. Let me know if I'm missing something obvious to report.
Thanks!
Thanks!
