Upper Steering Shaft Coupling
I disassembled the steering shaft in my Son's '80 CJ7 and replaced the upper bearing. When I began reassembly, the splined shaft coming out of the firewall only penetrates the coupler about a half inch. I noticed the shaft is notched to accept the pinch bolt. The splined end certainly does not stick out far enough to align the notch with the pinch bolt. I confirmed that the shaft is not pushed back into the column and everything is good at the steering wheel. Does this shaft collapse or have a slip joint? Maybe the incorrect shaft was installed previously? Help!
Read more: http://www.jeep-cj.com/forums/f19/upper-steering-bearing-6454/#ixzz2WCDqaIz0
