Valve cover gasket
Rollie
- Ames, IA
- 1975 CJ5, Basically stock except for electronic ignition.
I am chasing leaks like crazy. I replaced the clutch, put new seals and gaskets in the Transmission and in the Transfer Case , replaced the rear main seal, and while doing all of that I noticed that there is a lot of oil on the back of the engine below the valve cover. So of course I am attacking that as well. I know that leaking valve cover gaskets is a common problem, so any tips to help make sure I get this one stopped as well would be appreciated? Thanks.
