Valve Cover Gasket
Scout1067
Old Time Jeeper
Is it common for the cork valve cover gasket to crack?
I have what looks like some oil seepage from the back side of my valve cover gasket and the oil inside the cover is foamy as if there is moisture in it. I am starting to think that the two are related and the gasket has a crack that is allowing moisture into the cover. I have no idea when or if the gasket was replaced but looking at it away from the suspected leak it looks fairly new. Of course, it could be that the PO put it on and either over-tightened the valve cover bolts or used too much RTV where none should be used. My dad has always told me to not use RTV on cork and at most use Vaseline if I need to be sure of a seal on cork.
