valve lapping compound
cerrajero
I just started a DIY head rebuild. which was only going to be valve stem seals. But if you go that far you might as well right?
I went into the local mega super auto parts chain to get a valve spring compression tool and some lapping compound......
tool.....check
valve grinding compound.....well 5 employees at store and none knew what that was
ok....how about lapping compund? 1 employee started laughing and said "your in the wrong type of place for that"
so I left and went to NAPA. Even there the man behind the counter said he didnt know what it was.I tried to explain it and he told me that was a special order..........???????
ok now that the head is all torn apart and soaking overnight
Has anyone had any luck finding the 2 small can of compound , because obviously around here there is none to be found.
plus i will be posting pics of the head for suggestions #6 exhaust looks a little rough
tool.....check
