Engine Valve train noise
Manic Mechanic
Full Time Jeeper
Gold Supporter
Featured
Thurmont MD
85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
Long post I'm sorry.
Starting late last year my starter went out 30 couple bucks and two bolts later I have a brand new not remanded ac Delco starter. Very soon there after I developed a valve noise. The jeep would start fine be nice and quite and then as it warmed up I would get a slight noise coming from the front of the motor. As it got to temp it was a very pronounced noise. I drove it on and off over the winter and by this spring not at all.
Fast forward to now I'm going to Jeep week in OC Maryland so I decided to try and fix it. I figured a collapsed lifter was to blame so I ripped my head off.
I took the head lifters push rods to my local machine shop. All push rods and lifters checked out just fine. So I left the head to be stripped cleaned up have the valves and springs checked and new seals installed.
I cleaned and reassemble the motor (nothing was found to be bad in the head) with everything back to together I fired it up and sure enough the noise is still there. I thought maybe the fuel pump it's in the front and mechanical. I replaced it with a new one and still there is a noise. It's to "soft" and high pitch to be a rod knock or main bearing.
I'm kinda at a lose and pretty much ready to just let the motor die and begin cleaning up my stroker that's been sitting in my barn for several years now and drop it in. But before I do anyone have any ideas I'm wondering if maybe my starter Bendix is not fully retracting and what I'm hearing is the fly wheel brushing on the starter gear. Any thoughts?
BTW it's an 85 CJ7 with the AMC 258 i6 / 4.2l in line 6 bored 40 over mc2100 carb hei ignition emissions anything is gone and the only vacuum is the power breaks and advance for the distributor.
Sent from my E6810 using Tapatalk
Do you have an extra starter on the stroker you could try ?
I'm going to check in the morning if not I'll buy a new one throw it on and if it doesn't fix the problem just return it
Its a frequent complaint of the smaller cousin 4.0. Noticeable on 3 out of 4 I'm around frequently, with one being my wifes 97 GC w/210k on it. Always assumed it was a higher mileage trait of the AMC 258 i6 / 4.2l /4.0. The noise is slightly obnoxious, but the ones I've been around just keep chugging (or ticking ;) ) along.
