water pump
andrea
- Media
- 48
- fort loramie ohio
- 1984 cj7, 1975 bmw 900cc,525 outlaw polaris, honda shadow 600 cc
CJs arent reverse threaded that wasnt invented till after we got fuel injection..... to remove the fan loosen the 4 bolts that hold it to the water pump then loosen the belt and it will come off...it took me longer to type this than it will take you to remove itCan you share the procedure/tip to remove the Wp fan please. Do you need a special wrench for fan? I know she is reverse thread.
One issue when it comes to removing the fan is when you turn the nuts the whole waterpump shaft tries to turn. Then you can't grab the fan because the fan clutch turns. Here's what I do: I loosen the nuts for the fan before I remove the fan belts. This is what gert was talking about. That way the fan belts help hold the pulleys and water pump as you turn the nuts. Just loosen the nuts. Once the nuts are loose and you know you can remove them the rest of the way you can remove the belts.Can you share the procedure/tip to remove the Wp fan please. Do you need a special wrench for fan? I know she is reverse thread.
Either Gert is a very slow typer or I am a very slow mechanic. Either way this should be an easy job. Let us know if you have any trouble....it took me longer to type this than it will take you to remove it![]()
