Water temp and fuel gauge problems
No, the sending units are grounded not the gauges. In other words here's how the circuit works: 12 volts is supplied to the gauges. Current flows through the gauge to the temp sensor (or fuel sending unit) and this sending unit supplies the ground.I guess there is a ground problem in the dash. Would running a new grnd wire to the gauge cluster work. Thanks again.
Check out the 2nd and 3rd section of this post for some great gauge trouble shooting info...~~~ The factory fuel and water temp gauges do not work. ~~~
Older CJ's have the emr drv light on the right instead of the 4wd light on the left. They only work with a QuadraTrac in those years. When jeep went to the Dana 300 they switched the brake and emer drv lights from one side to the other, changed it to 4wd and put a switch in the Dana 300 Transfer Case .Yes. True. Dana 20 has no 4WD switch to illuminate a light. Which is why it is even more odd that I have this instrument cluster. But I'm pretty sure you could get QuadraTrac in 78'. A friend of mine who is a venerable Jeep God here in Maryland says that in those days they virtually threw in any one of many gauge variations they had.
Just took a nice 83 CJ5 in on trade for a classic truck that I owned. The factory fuel and water temp gauges do not work. I changed two accessory fuses and replaced the water temp sending unit and this did not fix the problem. Any suggestions would be greatly appreciated.
