Weber 32/36 DGEV on 258 pics need help
rpsharpe
I have read numerous threads on this site as well as install instructions from Weber web site.
The PVC is attached under the air cleaner, the other valve cover fitting (breather elbow) is capped off.
On base plate on rear of carb there is a threaded hole for a PVC fitting, but the throttle linkage is in the way. Right now, it has NOTHING in it! Just an open hole! Weber instructions say that this should face the front of the vehicle and I don't know if I need this attached to a PVC valve or not.
I do have a fuel pressure regulator which is nice.
The last issue is oil blowing from front PVC and oil fill cap (fits loosely)
Any help would be greatly appreciated. Also, any recs from the photos on any unrelated item also desired and respected!
