Weber 32/36
Weber 32/36
Dayle
Cedar Rapids Iowa
1984 CJ7 only mod motorcraft 2bbl no emissions on it after a fire, 195? CJ3B project have not start on it yet
Hi Looking for some one on the forum that has had experance with Weber 32/36 carb. I need to know what jets you are running. This is mostly a daily driver. Any help? Thanks Dayle
Check Cleaning Weber 32/36 - JeepForum.com post six. The short answer is "75/60 idles, 145/145 mains with 170/160 air correctors".
cheers,
kim
Hey thanks for the onfo. When i tear mine down i will see what i have or need to change. Do you use yours as a daily driver or trial jeep? Have you ever check it for gas mileage? This year i will have mine on the road more than trails, would like to get most MPG i can get. Thanks again Dayle
I've been checking since last april when I got it. ~12-13mpg at the start. TFI and carb tuning got me to ~15mpg now. "Nutter" may add a bit as well and I'll do it once it warmer.
Mine is a daily driver in summer topdown weather. We hit the beach rather than trails. My commutes are under 15 miles and sideroads primarily, so top speed is ~55mph.
I'm likely my own worst enemy for using 5th gear at those speeds. With a T-5 , 3.31 gears, and 31" tires, the engine rpms are a bit lower than the "sweet spot". I'll have to try sticking with 4th gear when under 60mph for a tankful and see what that shows me.
There's a wealth of good 32/36 and Weber in general tuning info here, on JF, and countless other places on the net. A timing light, vacuum guage, tach, and patience are really all that's necessary.
cheers,
kim
$35.00
  17.5%
