Weber 38 idles high after driving a while
Texas CJ7
- Media
- 12
- DFW, Texas
- 1980 CJ7 - 4.2L, SR4, D300, Dana30 (w/LockRight),AMC20 (w/Superior 1pc)
Hey guys, I usually figure most things out through some searching and what not but I have an issue that I can't find any help on...
I put on a Redline Weber conversion to dump the Chinese mc2150 that I had (tired of futzing with it every other week), everything went well got it pretty well dialed in and the motor is running better than it ever has (gained a few mpgs even with my issue).
The problem is that after driving around a bit the idle tends to stay up around 1000 rpm rather than dropping down to the curb set at 700 rpm. At first I figured it may be just be a little bind in the linkage, couldn't find anything, or possibly stiff joints fighting the return spring so I went through and added a little lithium grease to the joints and drove it to work a few days to see if it would loosen up with a little movement but it is still doing the same thing.
Any ideas as to what I should look for?
Thanks,
Tony
Thanks,
Tony
