Weber Carb
I am needing some help with a new Weber. I don't seem to be able to get any resolution from the supplier.
I have an 82 CJ7 with AMC 258 i6 / 4.2l . Rebuilt.
I have finally gotten the motor to run ok but it will not start without pumping the throttle about a hundred times or priming the carb when it is cold. No problem when it is warmed up. It does not seem to be getting enough squirt when you look into the carb and open the throttle, but when it is warm it accelerates ok. 22 in of vaccumn at idle, spraying everything while running shows no vacumn leaks. I have been into the carb several times. Did have to set the floats as the factory settings were way off. At this point I wish I had not bought it. Anyone out there with any experience would be a big help.
