Weber Help
82Laredo
- Wake Forest, NC
- 1982 CJ7 Laredo - 4.2L, T5, factory 3.30's
1993 Z28 M6 - bolt-ons, cam, s-trim w/alky = 488rwhp
I installed a new 32/36 DGEV with a holley regulator a couple months ago on a 82 CJ7 258 I had just purchased. It ran like poo with the stock carter which led me to the weber conversion. After installing it was running and idling great without any adjustment but it seemed down on power, would only go 65 mph down hill. First things to check are timing (already installed new plugs/wires/cap/rotor) and making sure its going WOT. The timing is spot on now but discovered I wasn't getting wide open throttle. I adjusted the linkage to compensate and that's where the trouble began.
Symptom: When I get into the last 20% of the pedal it starts bogging/hesitating and occasionally pops back through the carb. It does this whether under load regardless of gear or RPM, or free revving.
I reduced the fuel pressure from 4.5 to 3.5 and this made no difference.
Decided to check the float level even though its brand new and my measurements don't really make sense compared to what I've found on the web. It has the plastic floats and the measurement I've seen on the internet shows 35mm with the top held vertically and 51mm with the float hanging (top perpendicular).
With a digital caliper I measured 37mm and 44mm. The plastic float itself measures 26.5mm. How do I adjust to get those settings, seems like no matter what I'm always going to have a 7mm swing in between. Maybe I'm looking at it wrong.
Any thoughts on this or my carb problem???
Thanks for the help guys, I have already been through so much getting this rust free CJ road worthy I'm about burnt out, and I bought it for my wife
