Weber questions
Ok so I got the Weber in and throttle response is definately improved. The problem is when I dump on it and the 2nd barrel kicks in I get a flat spot and thats it. It doesnt pick back up till I ease off the throttle. I looked at it in the driveway and the butterfly opens and fuel sprays in. It only does it under load. All the linkage seems to be working correctly.
Also I have my vacumm advance hooked into the side of the carb in the first pic. Is that correct? The second pic is vacumm directly from the manifold. What if anything should go there? Lastly I have the pcv valve hooked directly to the canister but nowhere else. There is another port aside of the one I used for the advance that has a screw in it. Should I unscrew it and use that port? Sorry for the long post.
