Weight of Iron Duke
Weight of Iron Duke
Super8mm
Silver Supporter
Bronze Supporter
Grapevine, TX
1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case.
Start a heart transplant mid November with LS1 and SM465 :-)
Does anyone know how much a Iron Duke weighs?
350lbs
AMC AMC 258 i6 / 4.2l 500LBS
AMC V8 (AMC 304 360 etc etc) 540LBS (one reference said 600)
small block chevy 575LBS (generic for 60's-70's)
Ford 289/302 460LBS (later 5.0's are a bit heavier)
GMC 4.3 425LBS
here is some common engines ppl swap into cj's and how much they weigh
350lbs
GMC 4.3 425LBS
Thanks, that wont be so bad on the suspension as the LS1 I am going to put in is 390 lbs.
What is your plan for your old Duke? If you were just going to get rid of it, I may be interested in giving it a new home.
I dont know yet but I wont be able to start the switch until May.
I just put a note on my calendar to check back here when I pull it out. it only has about 7K miles on it as the PO put this one in, it was a crate motor.
I just sent you a pm.
Keep me in mind if and when you do decide to part with the duke.
Good luck with the LS1!
  5.0%
