Welding AMC 20 rear-end
Swoop
- Gulfport ms
- 1984 Cj7, 258, T-4, Dana 300, Dana 30 in front and AMC 20 in rear.
I've been told that the AMC20 is a good rear-end as long as you truss the top of the rear-end for strength & weld the tubes. What size plate would you use to truss the top of the rear-end? Would 1/4 inch plate be good? Does the truss have to go all the way or would I stop it at the U-bolts. Another words does the truss need to go to the end of the rear-end and the U-bolts be knoched out? Do I need to weld the entire thing, or can I put like 2 inch welds down it? and What type of weld would I use stick or MIG? Can the tubes be spot welded? (like in 4 spots) or do they need to be welded all the way around? Does the rear-end need to be disassembled or can I just drain the oil out? Thanks for any info.
