what axles are you runing & why
I run Dana60's front & rear.
I do so because I run big tires, front & rear lockers.
Also I climb rock waterfalls & play in the mud.
That & I've grown tired blowingup.
then there are those who chose to go where I do notI run Dana60's front & rear.
I have the original AMC20 rear and Dana 30 front; some would hang their head in shame, but not me. I have every intention of using these forever. I will be putting one piece axles in the 20 with an air lock, an axle truss and disk brakes, it will be more cost effective for me to do this than to hunt for the 44 that will fit and do a total rebuild on it and having a debatably stronger axle when I am finished.
The front is scheduled for a lunch box/Aussi locker.
In the longhorns defense; he has one of the best engineered and built highway rated tractors I think you will find anywhere. And has an impressive knowledge of suspension and drive trains for equipment that could arguably pass for a lunar excursion vehicle.
I found this in CL tonight, I am going to E-mail him but I don’t think these are the right length for my axle, and I don’t see myself driving to Abilene to buy them. Full float axles would be cool and the price isn’t too bad.
http://dallas.craigslist.org/ftw/pts/1537544028.html
Damn IO, I can't believe your not jumping on that deal.
I would want drive flanges for wheeling, but the lockouts would be great for flat towing.
I got e-mail in to the boy, we will see, I think I would loose the hubs, if I was going to tow it it would use a trailer but like I said I don't see myself running to Abilene for them.
they should work, shouldn't they? as long as he isn't QuadraTrac ?
I run a Dana 30 AMC20 but they are not stock. Well the front is but I rebuilt it with Richmond gears and timpkin bearings. The AMC20 has an ARB Air Locker with Richmond gears, Moser 1 piece axles and Con-Fer spring plates. I also installed a Tom Woods CV driveshaft. I was sceptical about putting a V8 in front of my AMC20 at first but I know the carrier is plenty strong enough. The H1 Hummer uses the same carrier. ARB told me when I had to order a drive pin for mine so if it can handle a Hummer and can handle my Jeep. Also the Moser axles are Guaranteed against high horspepower motors. He told me straight up if I break one he will replace it free, no questions asked for the life of my shafts. I built these both back in 1998 and they have been flawless since them.
That guaranty has no tire size limit?
I don't know. He told me flat out they are designed for high horsepower and since he specializes in drag racing applications that he will warrantee any breakage I have. Now of course it has been 12 years since then and I have had no issues. Who know what will be said now.
It may use the same carrier, but differential is solid mounted.
No weak axles,No weak axle tubes, No weak wheel bearings, No leaking seals.
Corvette uses a solid mounted Dana 44 pulling 638 HP with a factory warranty.
