What gears could I have?
on the Dana 44 rear axle there should be a tag that is between two cover bolts. the last three numbers on the bottom line are your ratio numbers.
turn the wheel , you should be able to see if the wheel turns once for every 3 3/4 turns or 4 1/4 turns. :cool: doyou have one piece axles? or tapered two piece axlesin the Dana 44 ??
Dana 44 will not have tapered 2 piece axles...
If I were you I would pull the covers off and count teeth. Thats the only sure way of knowing.
The jeep will thank you for the new diff. oil.
It's always a good idea to look at the oil from time to time and be sure you are not making a "milkshake "in the rear axle. Of course that goes for both axles , tranny and TC too.:D
You don't really have to actually count the teeth - the ring gear will have the number of teeth stamped on it for both the ring and the pinion.
Example - 4111 = a 3.73 ratio (41 / 11 = 3.73)
