What is this?
You have a traditional bump directly over the axle tube. If you had a snowplow, the bottom bracket would be bolted right behind that for lack of a better term, sag protector. Snowplows are 500+ pounds with all the brackets, pump lights, etc and all the weight is on the front frame pushing down those springs. If you didnt have lifted springs, you would see how mucj closer that sag protector is to the spring pack. In any case, you dont need it. Feel free to remove.
