What kind of grease should I use?
Bearing grease would work but will also collect junk. I’d clean it up really good and spray it with pure silicone lube.
Slippery, water & gunk resistant.
With me getting older and my memory not what it use to be when I do a column I have to do it all in one day so I don't forget how it goes back together. The last one I did was a '92 Cherokee that the four bolts had gotten loose so it wobbled.
I wish you luck and hope you get it working in no time.
After today I feel I need all the luck I can get lol
Thanks. She’s all lubed up. Just having a hell of a time getting her back together. Got her almost done and installed the new lock cylinder. Well low and behold the key release wasn’t working. Took her back apart and shifted the ignition switch push rod back where it was supposed to go on the key release. Happy day. Right? Nope. Every time I turned the key to check everything the push rod would jump off the key releases. (FML). So tried again AND the ignition switch fell to pieces. Now I’m calling it a day for today and contemplating pulling the whole column to replace the ignition switch and get this thing back together.
This is why I love this forum...... just when I think I have cornered the market on crappy luck, I realize I'm not alone. Hang in there - you'll get it. Just look at your CJ like I do...... an inhouse, perpetual lesson on patience.
After reading this thread, I recall a recent one asking if any of us had named our Jeep's....... maybe I'll name mine "FML" LOL
