What lift without other mods.
Vikingone
I'm wondering how big a lift I can install without having to make other modifications?
Surely you recall the major ordeal I just went thru on one of mine with a 2” lift! Sorry if you don’t like to be called Shirley.Generally, 2.5" before you start getting in steering/driveshaft issues.
Would you please provide more detail on “special ball joints”? Thks!Caster can be adjusted with angle shims under the spring perches.
Just be sure you use steel shims, and not the POS zinc or alum ones that deform and 'pound' out.
Keep your caster to 6*-7* with correct toe-in for your wheel size.
Camber can be reset with special upper ball joints.
