What should it look like inside a locking hub
TroyaCantrell
Old Time Jeeper
- Media
- 8
- Orangevale, CA
- 1966 CJ 6, Buick V6 Dauntless,
Dana 44 rear, Dana 27 front
Trans GM SM 420
First Gear ....... 7.05
Second Gear ... 3.57
Third Gear ...... 1.70
Fourth Gear ... Direct
Dana T-case (twin stick)
1970 Glass dune buggy. Short pan 1600
2008 Chevy HHR SS
So I think I have a brake hanging/ grabbing on the front driver side so I am digging in. When I got the outer locking hub off I see a lot of grease, but it is thin, runny almost. Is this normal?
I am going to go all the way in and check things out but it seems like the lube should be behind a seal.
There is also what looks like RTV between the outer and inner hubs is this normal?
Troy Cantrell
Build thread - '66 CJ6 :
http://www.jeep-cj.com/forums/showthread.php?t=15075
Troy Cantrell
