Wheel/Tire experts please help.
Hello. Just got my tax return. My tires are old and have some rot, so I want to get some new ones. The abundance of info. has me confused.
Currently, I have the 15" rims with 31" tires. I have a small lift, shackles, that's about it. Got some good pics in my gallery if you want to see what I have.
My set up works good, but I would like something that looks bigger. I guess 31"s are tall enough, but a wider tire is desired.
Some of the things I'm confused about: Backspacing, do I need it? How about offset?
Alloy vs steel: I do very little off roading, (light trail, mud) and I would like to keep weight down. Should I go alloy?
I don't want something that will rub all the time, but I don't mind losing a little of my flex ability, as I said, I don't do heavy off roading anymore. My tires already get pretty close to the leaf springs when I turn hard.
I don't want something that will rob a bunch of power, or overstress my drum brakes, though I will accept some degredation.
So what size rim should I consider (height and width)? Do I need offset/backspacing? I don't mind if they stick out past the fenders some.
Tires, can I stay with 31's and just go wider? If so, what size would you advise?
By the way, as far as budget, I would like very much to stay under $1,500.
Thanx much! Pics of what I do will follow.
