Where can I get OEM steering damper mounts?
Astrodokk
- 1985 Jeep CJ7 Renegade- IL6 -Mopar FI -Tremec 5 speed- Acme hard top- pretty much stock.
I've searched threads and it seems that this question hasn't been answered yet. I understand that the current way of mounting is on the axle housing and the tie rod. Some folks complain that the position leaves much to be desired.
The stock mounting brackets for my 1985 CJ7 should be on the tie rod and leaf spring. I get a little bump steer and want to dampen that with a damper, and would like the OEM mounts. I believe they used the dampers with double ended studs.
